Re: Farmall Super C and an IH-45 bailer
Posted by RayP(MI) on June 27, 2003 at 19:03:01 from (216.46.196.186):
In Reply to: Farmall Super C and an IH-45 bailer posted by John T. on June 26, 2003 at 18:54:29:
Just got through bailing a load with a Farmall 200, (a Super C in disguise). Was running an Oliver 60 T,-pto driven- with a set of dull knives. Tractor handled it well in first gear, along with the waggon on behind. Only ran into traction problems going up a steep hill. Engine held in there, but was working hard. Looseness in two point hitch was a problem, as baler was pretty well balanced on wheels, and rocked up and down quite a bit, on loose hitch. Finally swapped for a JD B - but carefully used a Super C or 200 should do OK if you don't push it!
Post A Followup
: Re: Re: Farmall Super C and an IH-45 bailer
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
