Re: 706 TAclutch
Posted by Aces on June 28, 2003 at 08:52:10 from (67.0.5.47):
In Reply to: 706 TAclutch posted by TGIN on June 27, 2003 at 17:26:31:
Make sure you have good stands, you can remove the tank and steering column all at once if you have hoist, you can split at engine then at rear of TA you will have to move rear end back about the length of TA housing because of PTO shaft. After you remove the MCV valve on left side there are three tubs you need to remove before you can disassemble the TA. You should get a manual.
Post A Followup
: Re: Re: 706 TAclutch
