Re: Cub Ammeter Question
Posted by Doug in OR on June 28, 2003 at 11:55:12 from (12.225.51.197):
In Reply to: Cub Ammeter Question posted by TJ on June 26, 2003 at 09:47:12:
Usually only one wire goes on the one terminal. This would be the wire from the generator regulator. (I think it is the terminal on the left side, when viewed from the front). All other wires go to the other terminal. If your ammeter reads backwards, simply reverse the wires at the ammeter.
Post A Followup
: Re: Re: Cub Ammeter Question
