Re: 44 Farmall A Steering Problem
Posted by LarryE on June 28, 2003 at 20:09:12 from (209.214.64.144):
In Reply to: 44 Farmall A Steering Problem posted by LarryE on June 28, 2003 at 09:49:38:
Thanks Dave and Aces, the reason I thought it might have a busing is because the part has a grease fitting. The part that is bolted to the curve pipe is replacable, but what's up with the grease fitting. As you say Dave, it is probably worn and will need to be built up again. Thanks for the help.
Larry
Post A Followup
: Re: Re: 44 Farmall A Steering Problem
