Re: Help with a 1206-seals and gauges
Posted by K.B. on June 29, 2003 at 09:48:26 from (209.163.30.23):
In Reply to: Help with a 1206-seals and gauges posted by Chad on June 28, 2003 at 18:49:44:
There is a timing hole in the right side of the clutch housing, remove the cover and have a helper hold a prybar in the flywheel's ring gear teeth against the clutch housing to keep the engine from turning over while you torque the bolt. You could also do this from the inspection hole in the bottom of the clutch housing. A junkyard might be your best bet for the original black-faced guage.
Post A Followup
: Re: Re: Help with a 1206-seals and gauges
