Re: Ratio of Lead to Gas
Posted by Steve - IN on June 29, 2003 at 10:14:10 from (12.223.205.149):
In Reply to: Ratio of Lead to Gas posted by Charlie on June 29, 2003 at 08:13:56:
Charlie,
The bottle should give you exact instructions, a lot of lead substitutes have a dosage of 1 ounce to 10 gallons of gas.
The engine's need for a lead substitue will vary with the way you use it. Heavy loads, long running, and lean running require more - light loads, short runs and richer jetting requires less. If you pull the head and have hardened valve seats installed, you won't need a lead substitue at all.
Post A Followup
: Re: Re: Ratio of Lead to Gas
