Posted by LMack on March 30, 2009 at 06:37:41 from (74.190.2.103):
In Reply to: 48 farmall c posted by jim A. on March 29, 2009 at 19:32:38:
Check the casting numbers on the block and see if they match up (the letter code included will give the year of casting). Also, check the block serial number on the right side of the block near the Number 1 plug at the very front of the engine on a flat stamped almost behind the throttle control rod. Trace both to see if they were intended for a C. The part number cast into the head on the left side over the manifold may yield helpful information. The part number will be different for later engines.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
