Re: Gas problem on 424
Posted by Aces on June 29, 2003 at 12:46:28 from (67.0.5.112):
In Reply to: Gas problem on 424 posted by Keewaydin on June 29, 2003 at 10:26:27:
You are right solenoid opens needle when you turn on switch closes to stop desieling when you stop tractor many later tractors you could not adjust if you can adjust yous it will have a screw out end of the solenoid.
Post A Followup
: Re: Re: Gas problem on 424
