Re: Old oil seals vs new oil seals
Posted by Bob M on June 30, 2003 at 04:57:35 from (165.170.128.65):
In Reply to: Old oil seals vs new oil seals posted by Brad on June 29, 2003 at 21:00:29:
Brad - Not to worry!! Seal technology has advanced a LOT in the half century since your A was built. Elastomers like Viton have replaced the cow hide in seals. Results in more compact, better performing and longer lasting seals. There's no need to install 2 seals. As Dave_Id suggests unless you pack the space between the seals with grease, the outer one is liable to destroy itself from lack of lubrication after a while anyway. Best to save your $ and effort and install only a single seal.
Post A Followup
: Re: Re: Old oil seals vs new oil seals
