Re: Farmall A Left brake pedal
Posted by BIG JOHN on June 30, 2003 at 19:58:48 from (205.188.209.140):
In Reply to: Farmall A Left brake pedal posted by Joe on June 29, 2003 at 19:08:02:
Had the same problem. Ended up having to use lots of heat from the torch and a 5lb hammer. You will have to disconnect the brake rod and drive the shaft out thru the clutch peddle which is what is frozen to the shaft. Had soaked it in Kroil and PB Blaster for weeks with no results.
After I finally got it apart and cleaned up good I put it back together with pleanty of "Anti Seize".
Post A Followup
: Re: Re: Farmall A Left brake pedal
