Re: Converting 6 volt Farmall A System to 12 volt?
Posted by Jim on July 01, 2003 at 17:55:41 from (205.188.209.140):
In Reply to: Converting 6 volt Farmall A System to 12 volt? posted by Gary W Doyle on July 01, 2003 at 15:23:07:
I have changed several farmalls to a 12 volt system. I have used a delco alternator with a built-in voltage regulator. With this system, some new wiring is required. I have used flat iron {short pieces} to make mounting brackets so the pulleys will align. You will have to change
to a 12 volt coil or put a resistor in the hot wire before connecting to the coil if using a 6 volt coil.
Post A Followup
: Re: Re: Converting 6 volt Farmall A System to 12 volt?
