Re: IH424 Hydr cylinder repair cost estimate?
Posted by Haas on July 01, 2003 at 18:13:18 from (12.65.43.20):
In Reply to: IH424 Hydr cylinder repair cost estimate? posted by BlueLite on July 01, 2003 at 16:10:57:
I used to have a 424 that had this problem. As I recall, it required a new piston and seal rings for the lift cylinder which of course is internal to the unit. I think my bill was around $180 to have it fixed. However, the mechanic that did it used a Mahindra part, which fit. That part I think was less than $100, whereas the part from IH was nearly $200. If your piston is not worn, you may be able to have a machine shop cut an O ring groove and replace the leather seal that is original with the O ring. My mechanic was going to do that but the piston was too far gone and I had to have a new piston.
Post A Followup
: Re: Re: IH424 Hydr cylinder repair cost estimate?
