Re: Converting 6 volt Farmall A System to 12 volt?
Posted by Doug in OR on July 01, 2003 at 19:47:59 from (12.225.51.197):
In Reply to: Converting 6 volt Farmall A System to 12 volt? posted by Gary W Doyle on July 01, 2003 at 15:23:07:
If it works fine, leave good enough alone. If you are going to make changes, first of all you should change that to a negative ground system. Not a hard thing to do, and your electrical system will be more compatible with other options - electronic ignition for one.
If you decide to install an alternator (recommended), you will need negative ground anyway. Try using the Delco 10SI alternator. It is availabe and inexpensive. If you do not have the space for a 10SI, you can install a Delco CS-121. This alternator was used in GM vehicles from 1986 to 1996. It should start becoming available at salvage yards near you. Look for it in the small GM cars.
Read up on 12 volt conversions in the "Articles" section to the left of this page. There is lots of good info there.
Post A Followup
: Re: Re: Converting 6 volt Farmall A System to 12 volt?
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
