Re: F-12 Starting problems
Posted by 49 Cubber! on July 02, 2003 at 16:41:55 from (206.74.216.98):
In Reply to: F-12 Starting problems posted by Dakota Jim on July 02, 2003 at 15:21:49:
I have/had the same exact problem with mine.I went in and adjust he float so that the level in the carb would be just a little lower,that help for a little bit,but it did it again,so upon advice I got on this board,I put a second gasket on the seat and set the float back to where it was.That helped a whole lot,but I am still having problems.if I turn on the gas and use no choke and set the advance about half way,itll start by the second or third pull,most of the time.Also I thought the magnet maybe getting weak so ihad it recharged and puit in a new coil,points,and condensor.That really helped too.
Post A Followup
: Re: Re: F-12 Starting problems
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
