Re: Ignition timing on Farmall A
Posted by CNKS on July 02, 2003 at 19:39:15 from (207.178.96.214):
In Reply to: Ignition timing on Farmall A posted by BillWV on July 02, 2003 at 19:11:19:
There is a very small mark on the flywheel that you line up with the raised mark on the cast plate behind the oil pan. Hard to find but it is there. The mark may or may not have "DC I4" on either side. A timing light is not necessary. Line up the marks with # 1 at TDC, rotate the distributer about 30 degrees counterclockwise viewed from the rear, remove the coil wire from the distributer cap, turn on the switch and rotate the dist clockwise until you get a spark between the coil wire and the primary terminal on the dist. Doublecheck by hooking the coil wire under the dist cap clip so that the tip is a fraction of an inch from the primary terminal, crank the engine one rev with the hand crank until you get a spark. Check the timing mark, it should line up, or be very slightly past the mark on the cast piece (NEVER before).
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
