Re: F-12 Starting problems
Posted by Kenny on July 02, 2003 at 22:37:22 from (67.66.23.204):
In Reply to: F-12 Starting problems posted by Dakota Jim on July 02, 2003 at 15:21:49:
Make sure you have a good seal on the manifold on the block and to the carb. This causes your problem a lot. Get rid of those champions, they just cause trouble. get some autolite plugs. Double check the points in the mag, and make sure one side is rounded and in line with each other. One of my F-20's did the same thing a few months ago. I had to pull the point, file, clean, and made sure the gap was perfect. If your carb is flooding, then the problem in in the electrical (plugs, mag.) If there is no gas leaking (not flooding) then the problem is the seals on the carb, or manifold. That F-12 should always crank by the 2nd pull on the crank, at least all mine and others I have seen. Good Luck!
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
