Re: Re: Rough running F-20 - - - need your wisdom
Posted by 49 Cubber! Something els on July 03, 2003 at 07:36:16 from (206.74.216.103):
In Reply to: Re: Rough running F-20 - - - need your wisdom ! posted by 49 Cubber! on July 03, 2003 at 07:32:14:
The magnet could be weak causing that too.My Grandpappys old 30 has a weak magnet on it and thats almost exactly what it does,but it will cut off at about half advance.Runs great otherwise otherwise,just have to leave the advane alone.I dont run it much.
Post A Followup
: Re: Re: Re: Rough running F-20 - - - need your wisdom
