Re: Re: 23 deg tire tread vs 45: advantages and di
Posted by Hugh MacKay on July 03, 2003 at 10:00:10 from (216.208.58.150):
In Reply to: Re: 23 deg tire tread vs 45: advantages and disadv posted by rustyfarmall on July 03, 2003 at 08:40:58:
Rusty: Here is what I have noticed over the years; 23 degree will give superior traction on reasonably hard surfaces. I have 23 on my SA and 45 on 130 and 140. On loose soil and side hill doing row crop cultivation the 45 don't slide sideways as much as the 23 do. I found much the same a few years back with 560 and 656, both close in weight and hp. On a outright hard pull the 23 would out pull the 45 on most surfaces. Again where side draft was a problem the 45 I liked much better. I had 23 on my 1066 and with duals the side draft item didn't seem to be affected in that application. I will admit I never had anything to compare with 1066. That side slip is quite noticable with the 23 degree tire on jobs like row cultivation, plowing, forage harvester, haybine, baler, etc. The only one that is a real problem is row cultivation with center and rear gangs. The tractor will start running like a dog on side hills and rear gangs tend to knock out some plants. Especially true in potatoes where you are trying to loosen a lot of soil for hilling. One thing I found surprising is H, 300 and 504 were not heavy enough for 2 row in potatoes. It needed the M, 400, 560 and 656, to get the volume of loose soil for good hilling thus stopping sunburn of potatoes.
Post A Followup
: Re: Re: Re: 23 deg tire tread vs 45: advantages and di
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
