Re: Raking hay and my H manifold...
Posted by FC on July 03, 2003 at 11:16:10 from (66.84.205.26):
In Reply to: Raking hay and my H manifold... posted by Brent in IA on July 03, 2003 at 10:29:15:
There have been several discussions on the rusty manifold/pipe threads on here in the past and someone mentioned getting a new pipe already threaded and cutting across the threads (I believe using a hacksaw) so it will basically chase out the threads on the manifold. Another solution would involve getting a thread chaser such as a plumber might use to clean the threads on the manifold. I believe the new pipe trick might just give enough bite to do the trick if you are careful and be sure and lubricate it while threading it in. Someone else might have another suggestion. Welding it is another option, but not very friendly should you ever want to remove it in the future. I believe you can use 2" pipe with a tapered thread (pretty common). Good luck.
Post A Followup
: Re: Re: Raking hay and my H manifold...
