Re: B won't charge - need help!
Posted by Haas on July 03, 2003 at 18:40:52 from (12.65.24.122):
In Reply to: B won't charge - need help! posted by Rich on July 03, 2003 at 13:55:26:
If you grounded the F terminal on the generator, it should charge. If it did not, about all that can be wrong is the generator has not been polarized. Do that by momentarily connecting a wire between the gererator "ARM" or Gen terminal and the battery terminal of the regulator. You will see a spark. Be sure not to touch any other terminals with the battery wire, as you can ruin the generator or regulator. Also, I must note that the mounting bolts of the regulator must have a good ground or you will get nothing. If you have a new paint job, the paint can be insulator enough to keep the regulator from working. You may need to run a ground wire from the regulator mounting lug to a good ground elsewhere on the tractor.
Post A Followup
: Re: Re: B won't charge - need help!
