Re: Super C clutch adjustment
Posted by Haas on July 04, 2003 at 05:25:05 from (12.65.48.128):
In Reply to: Super C clutch adjustment posted by Duane on July 03, 2003 at 21:10:39:
You should have around 1 1/2 of free play in the clutch pedal. That is, 1 1/2 inch of travel before you feel the resistance of the main clutch springs. The adjustment for that is not through the hand hole directly under the clutch, but rather in the linkage at the back of the torque tube just in front of where it attaches to the transmission. You can see the rod with the nuts on it through the rear hole once you clean out all the crud that is probably in there. If adjusting the free travel does not fix the problem, then your clutch is worn out and you are going to be looking at a rebuild.
Post A Followup
: Re: Re: Super C clutch adjustment
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
