Re: 544 timing
Posted by K.B. on July 04, 2003 at 17:27:07 from (209.163.30.23):
In Reply to: 544 timing posted by Steve on July 04, 2003 at 13:40:07:
That's a C-200 four-cylinder. I haven't worked on any of those, but it is the four-cylinder version of the C-301 in 806 Gas, so here's what I know about the six-cylinders, it should apply to your four-cylinder. If you are checking timing at the front pulley, the reference mark is cast into the front cover. You REALLY have to have a clean engine to be able to find it. Look at the clutch housing, on one side there is a small plate held on by two 1/4" bolts, remove one bolt and slightly loosen the other, underneath is a timing pointer, and removing both bolts could allow it to move around. Use the timing marks on the flywheel.
Post A Followup
: Re: Re: 544 timing
