Re: teardown model A
Posted by BIG JOHN on July 05, 2003 at 16:02:45 from (205.188.209.140):
In Reply to: teardown model A posted by Michael on July 05, 2003 at 14:38:59:
Before you break your "A" in half take off your Hood, Grill, Raditor, Valve Cover, Head, and Pan first.
There is a good chance that you will not need to separate the tractor.
I would suggest that you NOT remove your Dist/Mag. This will keep your timing in sink.
You can usually do everything except pulling the crank or replacing the clutch without separating the tractor.
I sure wouldn't put it back together without replacing the front crank seal. You will need some help with this but lets cover that in another post.
GOOD LUCK
Post A Followup
: Re: Re: teardown model A
