Re: Farmall C - Touch Control Hydraulics
Posted by Hugh MacKay on July 06, 2003 at 15:57:50 from (209.226.247.105):
In Reply to: Farmall C - Touch Control Hydraulics posted by Tim on July 06, 2003 at 10:29:43:
Tim: On all of these touch control remotes I have seen there is device about 1/2 thick, same shape as manifold with the same 3 hole pattern. It fits between touch control unit and manifold and you use 1/2 " longer studs. That has ports for hydraulic remote hook up.
40 years ago I saw what you are trying to do, and while I cant remember the exact plumbing, I do know the return line went back to fill cap. Also I should warn you touch control does not have a very large resovoir thus you should have added resovoir for remote hydraulic operation, especially motors. Resovoirs were added to these by installing a container above the unit and coupling with a hose through fill cap. For max cooling return line should go to added resovoir.
Post A Followup
: Re: Re: Farmall C - Touch Control Hydraulics
