Re: Farmall 400 cam gear problems
Posted by Bob M on July 08, 2003 at 04:28:22 from (165.170.128.66):
In Reply to: Farmall 400 cam gear problems posted by MikeI on July 07, 2003 at 19:56:14:
Assuming you've been installing the cam gears properly, breakage like you describe is probably the result of the hydraulic system relief pressure being set too high. The relief valve that should limit system pressure to 1,200 psi. Higher pressures put excessive strain on the pump and it's drive. And since the pump driven by the cam gear, high pressure can cause the cam gear to work loose or it's hub to break - especially if you use the hydraulics a lot. (Been there done that….)
Post A Followup
: Re: Re: Farmall 400 cam gear problems
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
