Re: MD-WD-TD6
Posted by Haas on July 08, 2003 at 05:39:08 from (12.65.19.238):
In Reply to: MD-WD-TD6 posted by Geno-Wy on July 07, 2003 at 20:46:18:
The engines are the same. The engine has dry sleeves. If there is antifreeze in the oil, it's a cracked head, leaking head gasket, or corrosion of the cylinder wall.
Post A Followup
: Re: Re: MD-WD-TD6
