Re: Farmall H Weak spark from magneto
Posted by Earl S. on July 08, 2003 at 16:15:34 from (205.188.209.140):
In Reply to: Farmall H Weak spark from magneto posted by Brad L on July 08, 2003 at 15:49:25:
If this tractor has sit without running for 4 yr.The first thing would be to clean up the points and check the gap . Be careful do not use to rough of grit sand paper .I usually take them out of the mag to dress them. If pitted replace. The cond should be checked . If you don't have equip. replace it.Earl
Post A Followup
: Re: Re: Farmall H Weak spark from magneto
