Re: Farmall H not running right?
Posted by cooper on July 08, 2003 at 17:49:22 from (65.129.216.113):
In Reply to: Farmall H not running right? posted by John on July 08, 2003 at 14:32:54:
You might very well have loosened up some gunk by bottoming out your screw. Valve problem doughtful if all you did was mess with the carb. Run some fuel injector cleaner or some other gas additive cleaner to see if you can dissolve your problem. If that doesn't do the trick, completely clean and rebuild the carb. Might be due for it anyway????
Post A Followup
: Re: Re: Farmall H not running right?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
