Re: loader oil
Posted by Keith T on July 09, 2003 at 03:35:14 from (207.179.218.77):
In Reply to: loader oil posted by chuck on July 08, 2003 at 19:06:38:
Unless the 44 H it came off of had 2 way hyd. there would be none or nearly so in the cyls.
If it did have 2 way ,remove the couplers on both hoses and use a neighbors loader to raise and lower your loader .Remember tho that it will drain your belly pump to refill the cyls. if it has 2 way
Post A Followup
: Re: Re: loader oil
