Re: Wisconsin V-4 (a little OT)
Posted by Bus Driver on July 09, 2003 at 04:51:07 from (65.165.154.72):
In Reply to: Wisconsin V-4 (a little OT) posted by Jon Blanc on July 09, 2003 at 04:19:25:
These engines have the carburetor located in a really hot place. I think that the gasoline in the carburetor bowl boils when the engine is shut off after running and the result is a (fuel) flooded engine. Mine usually starts OK after sittng overnight. This rich mixture would tend to foul the plugs at next startup. Restarting when hot should be done with the throttle wide open and no choke. This feeds more air and less fuel to the engine during cranking. At shutdown, if your engine has a fuel shutoff, shut off the fuel and let the engine run the carburetor dry. This will prevent flooding.
Post A Followup
: Re: Re: Wisconsin V-4 (a little OT)
