Re: Oil Pressure- Super A
Posted by Aces on July 09, 2003 at 09:23:12 from (67.0.38.201):
In Reply to: Oil Pressure- Super A posted by PGNS on July 09, 2003 at 08:46:51:
The oil pan leak will not increase the oil pressure that thing you touch in the drain hole is the float on the oil pump. Most likly you got same problem I had wiyh my B the oil pump has pewter base and over time it will warp and then the gasket will not seal and the oil leaks out the base of the pump and you loose pressure so if the pan gasket leaks take it off and check the punpm then.
Post A Followup
: Re: Re: Oil Pressure- Super A
