Re: S/C Engine
Posted by Stan(VA). on July 10, 2003 at 05:33:05 from (208.59.156.210):
In Reply to: S/C Engine posted by BOBBY on July 09, 2003 at 19:54:27:
The block casting number (above the oil filter) will be 354898-R1(or2) if an original SC, a later replacement block would be 366xxx. The SA or C block would be 251xxx (sorry don't recall the whole numbers). It should have a water pump and the upper radiator neck/thermostat housing should have the spot for a temp gauge sender to thread in on the right side, just above the governor.
I have one sitting in my garage too; off a running tractor but has a repaired water jacket. So if it doesn't work out or need a running parts motor let me know ;)
Stan(VA).
Post A Followup
: Re: Re: S/C Engine
