Re: Re: REPLACED BRAKE SHAFT SEALS, STILL LEAKING,
Posted by Randy in NE on July 10, 2003 at 11:26:45 from (216.58.237.20):
In Reply to: Re: REPLACED BRAKE SHAFT SEALS, STILL LEAKING, WHY posted by oldrisbetter on July 10, 2003 at 10:22:26:
Also make sure that the seals are installed the correct direction. Usually the seal goes in so that the face of the seal is facing away from the direction of the oil source. This means that the side of the seal with the spring is on the same side as the oil source.
Post A Followup
: Re: Re: Re: REPLACED BRAKE SHAFT SEALS, STILL LEAKING,
