if it sat for quite a while, first thing i'd do is put some automatic trans fluid (dextron) in a pump il can and pull spark plugs, give each cylinder a couple 3-4 shots of fluid. roll the motor around a couple times to get it spread out. check to make sure you dont have any valves sticking, maybe run a compression test. if it all looks good, button er back up, and give er a shot of ether starting fluid in the carb and see if she pops. if it does, pull the carb apart and clean er up a little
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
