Re: Re: IH M (1952) carburator problem
Posted by DE M Man on July 11, 2003 at 22:07:52 from (207.112.225.72):
In Reply to: Re: IH M (1952) carburator problem posted by Dana on July 11, 2003 at 14:10:25:
In response to your question of how I redid my fuel tank. There was so much rust in the tank that I had to get rid of the big chunks. First I used drained as much fuel out of the tank as possible. I then left the tank off the tractor and open for awhile in order to make sure there wasn't a lot of residual fuel in the tank. (evaporation) Next I used a hot steam pressure washer to flush out the tank as much as possible. The pressure washer helps because the baffle in the tank can make it near impossible to flush out everything. I then drilled a hole in the rear, lower, bottom portion of the tank (pointed end at about 45 degree angle if the tank was level as it would sit on the tractor), that I would be able to weld a NPT threaded insert into at a later time. (This becomes important in the coating and etching process later.) I purchased a NPT plug and fitting at the local farm store. After drilling the hole I again pressure washed the inside of the tank and the hole allowed the tank to drain out. After getting all of the rust and gunk out of the tank I then welded in the fitting for the threaded plug. I wanted to make sure the tank was real clean so I used a 50/50 mix of muratic acid and water to clean and etch the tank. I put the plug in and rotated the tank at different angles and let it sit for awhile to dissolve any rust on the walls inside the tank. After I was satisfied that the tank was clean inside I drained all of the fluid inside the tank. The tank will begin to rust inside almost immediately after you drain it so you be ready to coat the tank insides almost right away. Before coating the tank inside there is one other thing to do. (especially because an M tank has a seam along the inside) The next step is most often forgotten by many doing their fuel tanks. You need to make sure the tank is dry with no muratic acid to continue eating away at the metal seams. I use a torch to lightly heat the seam along the outside of the tank to dry any moisture. I don't want to have the sealer cover and seal into the seam any water or acid. Once the inside of the tank is very dry use a tank sealer to coat the inside of the tank by putting plenty of sealer in the tank and rotating the tank around to slosh the sealer all inside on every sidewall. Depending on the size of the fuel tank you are doing you will be able to drain the sealer out after coating all sides back into the original cans and save it for another tank later. You can remove the plug from the fitting that was welded on in order to drain the sealer. I leave the tank to dry and then recoat the tank several times until I am satisfied that there is sufficient coating. Depending on the sealer that you use (it can be purchased at most automotive supply stores) you will need to give the tank ample time to dry before putting it back on the tractor for use. Good Luck If you have any questions reply to this response. I'll check it.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
