Re: Super M clutch sleeve disc installation
Posted by Kiwi BM on July 12, 2003 at 03:52:06 from (202.27.176.157):
In Reply to: Super M clutch sleeve disc installation posted by George E. on July 11, 2003 at 13:00:29:
I replaced the clutch and pressure plate on my Super BM this past week. Suggest you check these;
1) is the clutch plate around the correct way. The circular dust cover should face forward.
2) have you tightened down the fingers on the clutch pressure plate. You do this by inserting three of the holding bolts into the rear of the pressure plate. Tighten them up (as you did when you removed the pressure plate) and once the pressure plate is bolted in place then remove them allowing the fingers to open.Those three bolts then become complete the holding of the pressure plate in place.
3) Lastly try to insert the clutch plate, pressure plate all on the shaft and then ensure the shaft is located correctly.We found doing it this way we had no problems with setting it up.
We had a little juggling match with this lot, but we got the whole lot back in place and it works. There is an excellent contribution on this website I printed of on changing and M clutch and we followed it the letter. But sorry I cannot find it this evening.
Post A Followup
: Re: Re: Super M clutch sleeve disc installation
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
