Re: baffled on 200, won't start
Posted by El Toro on March 30, 2009 at 09:08:57 from (205.188.116.73):
In Reply to: baffled on 200, won't start posted by mefarmer04614 on March 30, 2009 at 08:49:23:
You need to check the fuel system, pull the carburetor and disassemble and soak in a container of carburetor cleaner. Then clean all the jets and blow out with compressed air. Then
install a carburetor kit. You need to check the gas tank for any gummy residue from old gas being left in there. The gas line needs to be cleaned too along with the sediment bowl. Once you have the carburetor installed then see if the engine will start. If it doesn't hold your hand over the throat of the carburetor and see if there's good suction. If there's very little suction pull all the plugs and squirt engine oil on top of the pistons then crank over the engine a few revs then squirt some more oil on top of the pistons then reinstall the plugs and see if it will start. Do a compression check if it won't start and see what the readings are. The rings may be stuck. You need good intake manifold vacuum to pull that fuel into the engine. Hal
