Re: Farmall B voltage reg.
Posted by steve on July 13, 2003 at 18:42:16 from (204.246.222.44):
In Reply to: Farmall B voltage reg. posted by Ken K. on July 13, 2003 at 17:19:52:
take both wires off the generator. ground the "F" terminal. start tractor and measure voltage across the "A" and "F" terminals. should be voer 10 volts on a 6 volt system and 20 volts on a 12 volt system. IF so, the gnerator is o.k. the regulator needs rebuilt or replaced.
Post A Followup
: Re: Re: Farmall B voltage reg.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
