Re: Water pump W-9
Posted by Roger on July 13, 2003 at 19:39:39 from (69.58.144.97):
In Reply to: Water pump W-9 posted by Joel on July 13, 2003 at 15:30:23:
Joel, If the W-9 water pump is like the H and M the two gease zerks are for different parts of the water pump. The one on the rotating fan hub greases the external ball bearings and the one on the fixed part of the water pump greases the water pump internal drive shaft. Roger
Post A Followup
: Re: Re: Water pump W-9
