Re: Home made 3pt for a C
Posted by Steve Mason on July 14, 2003 at 07:29:07 from (207.177.31.118):
In Reply to: Home made 3pt for a C posted by DANWV on July 12, 2003 at 20:47:23:
third party image
Here my 3 point set up on my C.
Since its all red its kind of hard to see - I've outlined the left side bracket in blue. I made 2 of these brackets to bolt up to the rear of the transmission instead of on the axles. The brackets have a 1 1/2" pipe welded between them. A 1 1/4" solid steel shaft goes through the brackets and pipe so it swivels. Toplink bracket is welded to top of 1 1/2" pipe. upper lift arms are welded to the ends of the 1 1/4" shaft. Another arm is welded to the left side of the 1 1/4" shaft to connect to the touch-control.
The lower lift arms are attached to the drawbar.
I removed the drawbar and drilled out the 2 holes that are for adjusting the drawbar up or down to accept cat 1 pins. Spacing was perfect.
The leveling arms are from a Ford 9n (I think) that I picked upi at a salvage yard.
I have $150 in it and it works great so far.
Post A Followup
: Re: Re: Home made 3pt for a C
