Re: disk plow
Posted by Haas on July 14, 2003 at 18:15:31 from (12.65.73.147):
In Reply to: disk plow posted by Ron on July 14, 2003 at 10:11:48:
I don't know the model number of your plow. But...I used one many hours in my youth. It takes a good 2 to 4 hours to mount the thing on the tractor, even when you know what you are doing. And keeping your religion will doing it will be a challenge. The parts that mount to the axle are only the lifting attachments. There should be some hydraulic cylinders for use with the Lift All. The plow pulls from a drawbar mounted under the tractor. This is not the swinging drawbar attaching point. The drawbar mounts to attaching points forward of that with a brace to some mounting holes on the rear of the clutch housing. Around where the lift all is. The drawbar is on both side of the tractor and and a large heavy bar, maybe 1 1/2 or 2 inches in diameter attaches to both sides. The plow attaches to this with a clevis. The bar has clamps on it so you can set the plow correctly for the wheel spacing of the tractor. Also, there is a bracket that mounts to the front wheel pedestal of the tractor. A bar runs from that bracket to a linkage on the plow that steers the back wheel of the plow when you turn the tractor steering wheel. Needless to say steering the tractor with that plow on there will develop your back muscles. I have seen a few tractors at auctions that had some of the parts for this plow on them. Namely the bracket for the steering and the drawbar. I don't recall ever seeing one of these plows set up at any tractor show I have been to in the last 3 or 4 years. I have been to at least 20 in that time. If you get it set up, it would be an interesting, but tough to transport item.
Post A Followup
: Re: Re: disk plow
