Re: IHC 460 shifter problem
Posted by Aces on July 15, 2003 at 13:18:45 from (67.0.7.229):
In Reply to: IHC 460 shifter problem posted by mark on July 15, 2003 at 12:32:53:
You need to adlust the clutch linkage first, the TA clutch must reliese the same time the main clutch or it will hang in gear and sometimes bad if adjustment is off alot.
Post A Followup
: Re: Re: IHC 460 shifter problem
