966 starter still running. Hugh! , Guys! HELP
Posted by John A. on July 15, 2003 at 17:40:44 from (208.24.233.53):
I needed to move my 73 966 awhile ago. She started up just like always, put her back in her usual spot shut her down just fine. BUT what is that noise, The starter is still running! I grab a wrench and get the batt cable off it stops. So I check the starter button, Tap on it a little, set the cable back on batt,starter starts up again! Then unmount the porition on the dash that has the Tack,light switch,& starter button. Remove the two wire clips from button, set cable back on batt, starter takes off again.
What is in this circuit, that I am missing that would cause the starter to actavate without the starter button being depressed. ANY & All Help is sought.
Thanks
John A.
Post A Followup
: Re: 966 starter still running. Hugh! , Guys! HELP
