Re: Re: 424 FLOW CONTROL VALVE
Posted by Jon,NH on July 17, 2003 at 03:46:54 from (206.152.188.131):
In Reply to: Re: 424 FLOW CONTROL VALVE posted by DAVE on July 16, 2003 at 12:31:12:
Like Plid,I'm assuming you have either changed or added hy-tran...and you have cleaned the filter.Now,doing either one of those tasks the hyd system has loss its prime.The whine you are hearing is the hyd pump,there is not enough oil flow to the pump.The loader works and not the power steering.If this was my tractor its telling me the system needs priming.Have you already primed the hyd system?
Post A Followup
: Re: Re: Re: 424 FLOW CONTROL VALVE
