Re: Marvel Schebler
Posted by gene bender on March 10, 2009 at 06:22:19 from (67.55.226.145):
In Reply to: Marvel Schebler posted by dougie94 on March 10, 2009 at 06:02:02:
Leaks bad plug wires bad plugs hows the compression are the readings close to each other plugged air cleaner timing anyone of these things or a combination. I just bought a B foun two bad plug wires and those plugs were fouled it has a mag and rotor was off one tooth. Also found out the gear that runs mag is not in registration as #1 fires at the 11 oclock instead of 1 oclock. You just never know what someone has done over the yrs.
