Re: Can Anyone Figure this Out?????????????????
Posted by g pop on July 18, 2003 at 18:49:59 from (206.72.63.216):
In Reply to: Can Anyone Figure this Out????????????????? posted by BIG JOHN on July 18, 2003 at 14:33:25:
check the wire from the coil to the dist.,a bad connection on either side ,caused by rust,etc,can make a open .i have seen this sevaral times.
Post A Followup
: Re: Re: Can Anyone Figure this Out?????????????????
