Re: Farmall B Steering Gear Volume
Posted by scIN on July 19, 2003 at 19:54:32 from (12.55.86.30):
In Reply to: Farmall B Steering Gear Volume posted by Roger on July 19, 2003 at 19:31:02:
I just looked in my manual and it said approx. 1 quart of sae 90 wt oil. Also that you should change it once every season or every 1000 hours of use.
Post A Followup
: Re: Re: Farmall B Steering Gear Volume
