Re: Can Anyone Figure this Out?????????????????
Posted by Jimmy King on July 19, 2003 at 22:52:31 from (63.189.17.227):
In Reply to: Can Anyone Figure this Out????????????????? posted by BIG JOHN on July 18, 2003 at 14:33:25:
This is proably not the problem, but once years ago on the H it would do simlar to that finaly Dad called an old wrench spiner with a lot of service manuals packed between his ears. After a while he found problem said he had never seen it before the cam surface on the points was partly broke and was hinging so the points would open for a while then not for a while. O'h ya Hugh I had an Olds. once the ck engine light came on shortly after I bought it several shops later still on drove car 4 years was still on when I traded it off.
Post A Followup
: Re: Re: Can Anyone Figure this Out?????????????????
