Re: Re: 1941 Farmall A throttle problem
Posted by Jeff Dawson on July 21, 2003 at 02:54:47 from (64.12.97.13):
In Reply to: Re: 1941 Farmall A throttle problem posted by Dhuth2 on July 21, 2003 at 00:19:01:
Yes, I did have the governor off of the engine to replace the gasket. I did take the governor off again to check everything and could not find a problem. One thing I forgot to write in my original message was that with the engine off, the throttle works fine (carb adjusts from idle to full throttle with the linkage). When the engine is running, it idles no matter where the throttle is placed and will only accelerate when I manually push the rod between the governor and carb. Any more ideas??? Thanks for the reply.
Post A Followup
: Re: Re: Re: 1941 Farmall A throttle problem
