Re: Farmall Super A Loaded Tires
Posted by Haas on July 21, 2003 at 16:56:35 from (12.65.24.71):
In Reply to: Farmall Super A Loaded Tires posted by Mike@NY on July 21, 2003 at 11:27:31:
You can safely fill the tires to the maximum recommended with calcium (or alcohol) solution. That is up to the level of the valve stem with it at the top, which leaves air space from valve stem up. I'm not sure how much weight this would add, but I expect around 300 lbs per tire for 11.2 X 24.
Post A Followup
: Re: Re: Farmall Super A Loaded Tires
